adding --max-age parameter to cloud sync task
zpj61
I need to add --max-age parameter to cloud copy task from gdrive.
How this could this be done?
It can't. (Nor can it in SCALE)
You'll need to abandon the option of using a cloud sync task and use rclone with the full syntax in a cron task.
By all means look for a feature request or make your own using the Report a Bug link at the top of the page, but be aware that CORE isn't getting a lot of love in the direction of new features.
