Adramelramalech
- Jul 27, 2020
I have many HDD's with a alot of data. I can not simply unplug the disk and plug it into the free nas, it will ask to format. What should I do here?
Do you need to keep the drives, or do you need to keep the data? Do you need to import all the data at once, or could you stagger it as your finances allow you to get additional disks?
I think FreeNAS can help in your case, but you would need to import data into it, instead of attaching your current drives.
I bought a cheap saberent box and I attached this to my router
I think I can free two 8TB disks out of my 15. I put these into system
pool mirror-0 8 TB disk 8 TB disk
pool mirror-0 8 TB disk 8 TB disk 8 TB disk
pool mirror-0 8 TB disk 8 TB disk mirror-1 8 TB disk 8 TB disk
