Dragon07062
- Mar 14, 2020
So, this is my first post on this Community and I hope to get help with my smb share. I'm posting this because I can't really find a solution to my problem. That said, I worked with Freenas a couple of months now but this gives me a headache.
at first my specs:
At first I had just an smb share from the whole pool and created the folder on Windows. It's quite easy, but I don't think it's intended to do that if you want a good overview over freenas and want to add nfs shares or add a zvol because its going to be all in the same folder and easily saturated the 1GBit connection. So, I played some data tetris and made nested datasets in freenas to have a better overview and optimize the folder to the specific datatypes that are going to be stored there (like big record sizes for movies or iso files). Now, when I'm uploading something to it It's only getting up to 40-50Mb/s and it doesn't matter in which folder I'm uploading to. Surprisingly I still can download with 112MB/s like ISO files or so. I played around with the compression levels, record sizes, switched to a bigger cpu (I didn't buy it because of that, so don't mind), added RAM, added a 240gb SSD as caching devices but nothing helped.
This is my dataset structure:
I would appreciate your advices, because I really don't know what to do and if you need more informations I'll try to provide them as soon as possible.
at first my specs:
- Xeon E5 2620 v2 (...before the switch and a Xeon E5 2658 after the switch)
- 5* 8Gb ECC Registered RAM with 1333Mhz (yeah not 6, because one module is broken)
- Supermicro x9sri-f Mainboard
- 4x 2tb HDDs in RAIDZ1 (without the cache device)
- 80gb hdd as bootdrive
- LSI SAS 9210-8i HBA
