1x Realtek® RTL8125B 2.5Gbps LAN controller
Sush88
I have a Z490 Intel MSI Motherboard with the following LAN Controller, Unfortunately Freenas unable to detect the LAN.Anyone has success with the below.Your suggestions are greatly appreciated.
You won't find many folks here with experience with Realtek NICs on FreeNAS as the wisdom is to not use them.
Driver support is limited and the drivers that do exist (at least for versions 11.3 and below) are terribly unreliable even if you can use them at all.
A quick search of the Internet tells me that there is no FreeBSD driver for your NIC in any case, so it's Windows or Linux for you unless you buy an addtional (preferebly Intel) NIC.
tsb
I've come across this. Not managed to get it to work for me as yet but you may have better luck?
tsb
Update - managed to get the above method to work. I'm a bit of a newbie but happy to try help get it working on your system
