(admin, this was moved from the wrong location. please del: https://www.truenas.com/community/threads/100mbps-on-a-10gbps-connection-bottleneck.110255/ )
Thanks in advance for responding. I am building a TrueNAS system for the first time, and would appreciate any recommendations you have. My issues is that I am only able to transfer at 100mbps (12.5MBps) using SMB to Windows on a 10Gbps connection. I have not tried any other method. Below is my configuration, please note I wont be able to run any tests until Tuesday, so any thorough suggestions you have are greatly appreciated.
NETWORK: Cat6a cables with Ubiquiti 10Gbps switch
Ethernet Status from ifconfig: Ethernet 10Gbase-T (10Gbase-T <full-duplex>)
HARDWARE:
NIC: 10Gbps https://www.amazon.com/gp/product/B008F6ID0U/
OS Drive: SSD https://www.amazon.com/gp/product/B07DNLY1R2/
PSU: Corsair HX1200
Mainboard: ASUS ROG Strix B450-F II https://www.amazon.com/gp/product/B08KH1M1H4/
RAM: 64GB DDR4
CPU: AMD RYZEN 7 5700G
HBA: LSI 9207-8e (LSI SAS2308)
https://www.serversupply.com/products/part_search/query.asp?q=9207-8E
Expander: HPE 3Gb 24-Port SAS
https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c01733557
*Expander upgrade soon: HP 12Gb 36-Port SAS-3*
https://www.ebay.com/itm/165984546437
Drives (18 of them): Seagate Exos 20TB Sata
https://www.amazon.com/Seagate-Exos-20TB-SATA-ST20000NM007D/dp/B09MWKXR2T
OS: TrueNAS
Config: 3 vDevs, 6 drives in each vDev, each vDev on RAIDZ1
Everything else is default
HARDWARE:
PSU: Corsair HX1200
RAM: 64GB DDR4
OS: TrueNAS
