Setting up FreeNAS 9.2.0 with Transmission and Couchpotato as a DLNA-Server
zufallsheld
The configuration part
How exactly are you connecting to the VM?
Anytime I've ssh'd anything to do with Freenas, I ssh using putty to my main freenas ip .10 as root. Then anything relating specifically to the jails, I jexec jid tcsh. Now when I do that, the firt command
sudo apt-get update && sudo apt-get install curl wget
I get "command not found"
When I try to ssh directly into jail, my root, user name or the vm/musicbrainz password do not work.
So are you ssh-ing somehow through the virtualbox in the browser?
Do you installed the musicbrainz in a virtualbox? This is different from jails in your freenas.
If you installed it in a virtualbox you should ssh to the ip-address of the virtualbox-vm with port 2222.
JJT211
Ahhhhh.....thank you! I missed the port 2222 part!
JJT211
After entering the last command
./admin/InitDb.pl --createdb --import /tmp/dumps/mbdump*.tar.bz2 --echo
I got the below
vm@musicbrainzvm:/home/musicbrainz/musicbrainz-server$ dropdb -U musicbrainz musicbrainz
vm@musicbrainzvm:/home/musicbrainz/musicbrainz-server$ ./admin/InitDb.pl --createdb --import /tmp/dumps/mbdump*.tar.bz2 --echo
Use of uninitialized value $databaseName in string eq at ./admin/InitDb.pl line 480.
Mon Mar 30 22:18:49 2015 : InitDb.pl starting
Mon Mar 30 22:18:49 2015 : Creating database 'musicbrainz'
createlang: language "plpgsql" is already installed in database "musicbrainz"
Failed to create language plpgsql -- it's likely to be already installed, continuing.
createlang: language installation failed: ERROR:  could not open extension control file "/usr/share/postgresql/9.1/extension/plperlu.control": No such file or directory
Failed to create language plperlu -- it's likely to be already installed, continuing.
NOTICE:  schema "musicbrainz" does not exist
CREATE SCHEMA
CREATE SCHEMA
CREATE SCHEMA
CREATE SCHEMA
CREATE SCHEMA
CREATE SCHEMA
Mon Mar 30 22:18:50 2015 : Installing extensions (Extensions.sql)
Mon Mar 30 22:18:51 2015 : Creating tables ... (CreateTables.sql)
Mon Mar 30 22:18:52 2015 : Creating tables ... (caa/CreateTables.sql)
Mon Mar 30 22:18:52 2015 : Creating documentation tables ... (documentation/CreateTables.sql)
Mon Mar 30 22:18:53 2015 : Creating tables ... (report/CreateTables.sql)
Mon Mar 30 22:18:53 2015 : Creating statistics tables ... (statistics/CreateTables.sql)
Mon Mar 30 22:18:53 2015 : Creating wikidocs tables ... (wikidocs/CreateTables.sql)
Mon Mar 30 22:18:54 2015 : Pre-checking /tmp/dumps/mbdump-cdstubs.tar.bz2
Mon Mar 30 22:18:54 2015 : Schema sequence mismatch - codebase is 20, /tmp/dumps/mbdump-cdstubs.tar.bz2 is 21
Failed to import dataset.
Mon Mar 30 22:18:54 2015 : InitDb.pl failed
I went ahead and finished the remainder of installation of musicbrainz and headphones and im also getting this in my console messages every 30 mins
Mar 30 19:34:28 freenas kernel: <118>Mar 30 19:34:28 musicbrainz sm-mta[78444]: t2UCL8oK045372: SYSERR(root): hash map "Alias0": unsafe map file /etc/mail/aliases.db: World writable directory
I opened up Headphones web gui and could not search any artists. However, when I set the server back to musicbrainz.org, the search function started to work again.
JJT211
Wow, I think I figured it out. The problem is on line 28, "Schema sequence mismatch - codebase is 20, /tmp/dumps/mbdump-cdstubs.tar.bz2 is 21"
The sub DB_SCHEMA_SEQUENCE {20} needs to be changed from 20 to 21 in in the DBDefs.pm file, just cd up one directory and its in the lib folder
vm@musicbrainzvm:/home/musicbrainz/musicbrainz-server$ cd lib
vm@musicbrainzvm:/home/musicbrainz/musicbrainz-server/lib$ sudo nano DBDefs.pm
#Scroll down and change DB_SCHEMA_SEQUENCE value from 20 to 21
#Save and Exit
#cd back to original directory
vm@musicbrainzvm:/home/musicbrainz/musicbrainz-server/lib$ cd ..
#Execute the last 2 commands
Hasnt finished quiet yet, looks like its gonna take a while (like most of this musicbrainz install), but its looking good so far. Gotta get some sleep so ill let it go and report back
Its been sitting at the mddump/edit for like 30 mins now.....I do see plenty of CPU activity though.....hopefully its working
JJT211
Damn, that went allllll night, and failed at the end due to a lack of space??!?
Here's end of it right here
Tue Mar 31 11:00:18 2015 : ensuring editor information is present
Failed query:
        'INSERT INTO editor (id, name, password, ha1)
             SELECT DISTINCT s.editor, 'Editor #' || s.editor::text, '', ''
             FROM (
                 SELECT editor FROM annotation
             UNION ALL
                 SELECT editor FROM edit
             UNION ALL
                 SELECT editor FROM edit_note
             UNION ALL
                 SELECT editor FROM vote
             ) s
             LEFT JOIN editor ON s.editor = editor.id
             WHERE editor.id IS NULL'
DBD::Pg::st execute failed: ERROR:  could not write to hash-join temporary file: No space left on device at /home/musicbrainz/musicbrainz-server/admin/../lib/Sql.pm line 107.
at /home/musicbrainz/musicbrainz-server/admin/../lib/Sql.pm line 113
        Sql::__ANON__('DBD::Pg::st execute failed: ERROR:  could not write to hash-j...') called at /usr/share/perl5/Try/Tiny.pm line 100
        Try::Tiny::try('CODE(0x9ca1bb4)', 'Try::Tiny::Catch=REF(0x9c69334)') called at /home/musicbrainz/musicbrainz-server/admin/../lib/Sql.pm line 114
        Sql::do('Sql=HASH(0x9a06d18)', 'INSERT INTO editor (id, name, password, ha1)\x{a}             SEL...') called at /home/musicbrainz/musicbrainz-server/admin/MBImport.pl line 467
        main::EnsureEditorTable() called at /home/musicbrainz/musicbrainz-server/admin/MBImport.pl line 200
Tue Mar 31 11:05:02 2015 : InitDb.pl failed
The file below in the above directory was 74GB!
musicbrainz-server-20140514-disk1.vmdk
Think I may mount a new dataset to that directory and give it a try again.
JJT211
Wouldnt let me mount to that directory. Any ideas?
You mind directing me to your reference for making this part of the guide? There's an over abundance of info and most of it is really old.
zufallsheld
I followed the official install guide on this subject:
https://github.com/metabrainz/musicbrainz-server/blob/master/INSTALL.md#creating-the-database
If you don't have enough space, leave out some files:
To get going, you need at least the mbdump.tar.bz2, mbdump-editor.tar.bz2 and mbdump-derived.tar.bz2 archives, but you can grab whichever dumps suit your needs.
JJT211
Thx, been reading up the last few hours. Im learning alot about CLI and coding in general. I understand all the commands up to the last 2.
The best I can translate the first one is that it drops/deletes the default database?
The second, creates a new database, and imports the dumps from the ftp server we spent a few hours downloading. I see the wildcard is what imports the entire dumps. However, I cant figure out the syntax to do them individually.
Would it looks something like this?
./admin/InitDb.pl --createdb --import /tmp/dumps/mbdump.tar.bz2 && --import mbdump-editor.tar.bz2 && --import mbdump-derived.tar.bz2 --echo
I decided to start over from scratch some im waiting on that ftp DL which takes a while. So when im ready to create the database and if something doesnt go quite right, will I be able to start over by executing this
as opposed to deleting the entire jail?
Also, I stumbled upon http://forums.musicbrainz.org/viewtopic.php?id=5261 which sounds like a guy who ran into a similar problem. His solution, leads to yet another tutorial http://www.rootusers.com/use-gparted-to-increase-disk-size-of-a-linux-native-partition/ which explains how to extend the VM disk space. Sounds like a pain, but in the name of education, I may take the plunge and give it a shot.
zufallsheld
I don't know if two "--imports" work, so better just delete the unnecessary files and import the rest.
Maybe this will also help:
By default, the archives will be extracted into the /tmp directory as an intermediate step. You may specify a different location with the --tmp-dir option.
Yes, this should work.
JJT211
Started over from scratch, added schema change before last 2 commands, and everything went off with a hitch! Thx again for the help!
one800higgins
ah ok the trangui is for the client not to install on freenas, then I don't need a guide :)
I came here to ask the same thing. I figured it was like the uTorrent webui where you had to install the updates relative to uTorrent. I see now that it's an installable program... Which makes me wonder if there's a good Chrome plugin instead.
JonatanHost
I have followed this guide now point to point but my downloads from transmission stays in transmissions jail so plex and sickrage can't get to the files.
What is wrong?
STREBLO
In case anyone else was having trouble finding it like I was , I just wanted to let people know that the settings.json file for transmission has been moved to /var/db/transmission/settings.json.
STREBLO
I've got a question, what exactly is the downloads folder for in couch potato? If we are setting it to move the downloads to the movie folder and it watches the torrents folder, is the downloads folder only for usenet? Or is it used in some other way and am I not using it right ?
zufallsheld
The downloads folder is where couchpotato downloads the movies to. From there it gets moved to movies.
The torrents folder does not get written, only read for torrent files.
STREBLO
But couchpotato should have access to storage in the torrents directory right? In the first post it didn't show couch potato as having access to the torrents folder, was that just left out?
zufallsheld
There's no need for CP to access the storage in the torrents-directory. When you add a movie from CP it gets send automatically to transmission.
You could however put torrent-files in the torrent-directory and transmission would pick them up.
STREBLO
Oh, I see. I'm using deluge as it supports proxies until I can get a vpn working with transmission so it must be different..
