Good Morning Everyone,
I am having an issue with a new TrueNAS Core setup. It seemed to be running fine for a few weeks but now the middlewared service keeps failing. The file shares are still working when it does but I am unable to access the web portal. I am able to SSH into the unit and do a restart of the service to get it running again but I need to know the cause of the issue so I can stop this from happening.
PC Specs:
AMD Ryzen 7 5700G
16GB RAM
3 Samsung 1TB SSDs (1 for OS, 2 for data but not in a mirror as of yet. The second drive was just added and we haven't had an opportunity to to schedule a downtime yet to swap it to a mirrored mode)
There is also an hourly cloud sync task for BackBlaze.
I originally created a Cron task to run an rsync command in order to copy all data from the production drive to the spare. This was just to give a local backup until the mirror was able to be set up. However, that seemed to make things worse and the middlewared crash seemed to happen more often.
Any suggestions/help would be much appreciated!
PC Specs:
AMD Ryzen 7 5700G
16GB RAM
