Convert stripe to mirror... 2nd drive is slightly smaller
andyjay777
I have a "1TB" NVME drive in a stripe pool. Original drive = Intel 760p 1TB
I had planned to extend the pool to create a mirror with a 2nd "1TB" NVME. New drive = Sabrent Rocket 4.0 1TB
The Sabrent is 22.36GiB smaller.
Is there anyway to trim the original Intel 760p so it has the same usable size as the Sabrent?
SCALE-22.02.4
Arwen
No, not that I know of.
The only way to do this, is to create a new pool on the smaller NVMe drive. Then copy the data over, probably with ZFS Send & Receive, (aka Replication). Whence you are certain everything is good, you destroy the old source pool. You can now add the slightly larger NMVe device as a Mirror.
andyjay777
Replication seemed to work OK.
I created a new pool on the smaller NVME.
Set up datasets and a zvol (for my VM) (all with slightly different names!)
Created a manual snapshot of each dataset and zvol.
Ran the replication task below.
Change the VM disk location to the new zvol.
Changed the app storage for Agent DVR to the new location.
Arwen
Uh, replication should copy the datasets exactly the same name, because they are in a different pool. For example; You would not create anything on the new pool. The replication would do it for you.
Their is even a way to rename the new pool back to the old name, if desired.
