Mooash
- Jun 22, 2016
Hi all! My 2016 FreeNAS build is starting to show its age and its time for me to upgrade.
I'm finding it a lot harder to find hardware this time around including the secondhand market. My requirements haven't changed much, my system will be used to store data and run a few jails/plugins like Plex (including doing some transcoding). I'm considering storing some VM disks via NFS and Proxmox, but not sold on doing this yet.
With this in mind this is what I currently have in mind:
CPU: Intel Core i5-12500 3 GHz 6-Core Processor
Motherboard: Supermicro X12STL-F Micro ATX
Memory: Kingston Server Premier 32GB 3200MHz ECC Unbuffered DDR4 x 1 (leaving me room to upgrade)
Storage: Western Digital Red Plus 8TB x 8 in raid z2
Boot: Random NVME drive I find (not yet decided)
Case: Fractal Design Node 804 MicroATX Mid Toer Case
Power Supply: SeaSonic GX-750 750W 80+ Gold
I'm keen on the i5 because of its integrated GPU so I can do Plex transcoding via Intel QuickSync, this is one of the main reasons I'm looking at replacing my current system.
I'm not so keen on the motherboard as I'd ideally like one with 10-12 sata ports which this doesn't have. Is there a better motherboard option out there? The reason being is I'd like to make an additional ZFS pool with SSDs in it to run some VM disks off like my 2016 build had. I'm currently capped at the on board ports on this motherboard.
Is this motherboard still a good option with this in mind and I'm best off getting a PCI controller/card or something?
Thanks in advance for any help!
